it has to be set on a tilt in order to drain out the rear if it's condensating really bad it may need a freon charge you should take it out and wash it real good
You should unplug your unit if you have not already done so. The problem is the start switch is stuck in the on position, this can happen when the switch fails (melted inside). You will need to replace the start switch. They are usually inexpensive and easy to replace.Here is a link that should help http://appliancehelponline.com/dryerselectorswitch.html the video is of the selector switch but the start switch will be similar. Enter your model # if you need diagrams and illustrations of your specific model.
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
