Question about Motorola Mobility Karma QA1 Cell Phone
Motorola Karma will not charge. When hooked up to charger screens displays at&t logo, then fades. Does this repeatedly. Will not charge and will not boot up. Still under warranty, just received the new phone. Same thing is happening. Could this be the battery? Or the charger?
SOURCE:
  • 35 Answers
SOURCE: Motorola V551 Unable to charge
Make sure that you are inserting the charger perfectly strait into the phone so that both metal connector snap into place, at work we have a data base of different phones (not the V551) but we have the V600/V300/V330 and all have known issues for not taking charge as people do not attach the charger correctly. If this isnt the problem next step would be to try another charger, if you have a friend with a Vxxx series phone all chargers are pretty much the same, if you have had the phone for less then 90 days most carriers will warranty you charger and sometimes the manufacturer will warranty it for 1 year. If its a problem with the phone then the carrier and manufacturer offer 1 year warranty. If there is a cingular store in your area you could also try going there to test your battery in another V551 to narrow down exactly were the problem is.
Posted on Aug 28, 2007
SOURCE: Motorola E815 - Battery Charger
The E815 has a very poor design on the charger port. The cleaning that Solution #1 referred to is that Verizon cleans the contacts of both the phone and the charger using rubbing alcohol on a toothbrush to clean both the phone contacts and the charger contacts. I have to do this once a week or so to keep my phone charging. The rubbing alcohol dries quickly and will not harm the phone. Motorola has changed the charging ports on the newer phones because they recognize that they have a problem with this design. I have also turned in my phone to Verizon (twice) for a replacement. If you replace the phone be careful to record ALL your contacts because when Verizon transfers your contacts from the old to the new phone the speed dial numbers all get messed up because they start their numbering differently than you had it. I am still repairing my speed dial numbers. Hope this helps.
Posted on Sep 07, 2007
damanone
  • 77 Answers
SOURCE: Motorola i880 white screen flashes i880 won't charge
the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
Posted on Aug 02, 2009
walesarumi
  • 6993 Answers
SOURCE: charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Posted on Nov 16, 2009
  • 152 Answers
SOURCE: I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
Posted on May 25, 2010
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
How to use motorola unlock code
You can use Unlocking instructions to enter the unlock code in Motorola KARMA QA1....Visit the site
Simpleunlocking.com/motorola-karma-qa1/rs16wp9/ get Unlock code and instructions ,unlock it step by step..Unlocking instructions is below:
Motorola Karma QA1 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Karma QA1 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Karma QA1 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Karma QA1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Karma QA1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Karma QA1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Sep 13, 2012 | Motorola Mobility Karma QA1 Cell Phone
Someone please help me i am trying to get a subsidy password for my motorola karma qa1 imei # 356918021807287 my email is dcodadixon@hotmail.com please i am begging you guys.
Here are the unlocking steps for unlocking a Motorola karma QA1,1 - Switch ON your Motorola Karma QA1 with a NOT ACCEPTED SIM Card,
You can get the unlock code from www.Superunlockcodes.com this is the most trustworthy online site to purchase accurate unlock codes at very low cost. Unlocking process is very simple here.
Mar 31, 2012 | Motorola Mobility Karma QA1 Cell Phone
MY MOTOROLA KARMA WONT CHARGE OR TURN ON
Hi, You may try to use to use a different charger that will fit in to your phone or a different battery. It might be a failure on the battery.
Aug 13, 2011 | Motorola Mobility Karma QA1 Cell Phone
Hi - trying to charge my V535 but the screen displayes "unable to charge". what should i do?
Remove battery, clean the charging port, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Jan 19, 2010 | Motorola Mobility V535 Cellular Phone
I CANNOT CALL OR EMAIL BECAUSE MY KARMA SCREEN IS BLANK
We have fixed several Karmas with this problem. Please contact me if you still need your Motorola Karma fixed. Thank you.
-Jim Groves, Owner
BongoPc.com Computer and Cell Phone Repair
863-206-7560
Jan 01, 2010 | Motorola Mobility Karma QA1 Cell Phone
Mar 24, 2009 | Motorola Mobility i880 Cellular Phone
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility Karma QA1 Cell Phone Logo
221 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
