SanDisk Sansa Fuze MP3 Player Logo
Posted on Mar 19, 2017
My Sansa Fuze 4G mP3 player locks up on an FM radio station and I cannot use ANY of the controls to get it to stop. The FM radio has been playing and I cannot stop it so I cannot play music. I tried the main controls, the main dial and control button to get me back to "home" and also tried the side on/off switch that also won't turn off the player. I have been able to turn it off twice and then when it restarts, the FM radio is still playing. I also cannot change channels on the radio. I cannot listen to my music or to my audio books and the FM station that is playing is not a good one. Something must be wrong or the unit is defective. I have a guarantee on the Sansa and I am thinking about sending it back to the factory for replacement if you cannot help me. Thanks, Holly
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 01, 2009
SOURCE: I loaded my music but it skips (cuts in/out) as does FM radio.
Make sure the songs are in the correct format - WMA or Mp3.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 31, 2009
SOURCE: sansa clip 2mg fm radio not putting out sound
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
Anonymous
  • 10 Answers
  • Posted on Jul 22, 2009
SOURCE: How do you record FM radio on Sansa Fuze?
OK, while in radio mode, press the bottom of the wheel, scroll down to 'Recording', then select 'Record Now'.
(I have a Sansa Fuse too, so, i know my way around it.).
this should help.
Anonymous
  • Posted on Sep 26, 2009
SOURCE: my sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Schmead10
Joe Negus
  • 652 Answers
  • Posted on Nov 02, 2009
SOURCE: my sansa fuze keeps freezing
Start the sansa updater, set sansa to recovery mode plug into computer. unplug when told sansa should restart (Lock sansa press and hold rec and menu until recovery begins)
Also you can Try
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
2helpful
Sansa mp3 4 g----message DSC -1157.JPG UNSUPPORTED MEDIA FORMAT PLAYER LOCKED ON THIS MESSAGE/SCREEN ALL CONTROLS LOCKED 4G SANSA MICRO DISK INSTALLED
You need to use the supplied Sansa Media Converter program to convert photos (and videos) to a format the Sansa can handle.
1helpful
My sansa fuze is locked and will not play
You need to reset the player --- to reset the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
See these tips posted here on this site --- Sansa Mp3 player frozen? How to reset and
Sansa View: is not recognized by my
Solve your MP3 Player Connection Problem.
How To Download MP3's To My Player.
2answers
How do I record FM radio programs and transfer them to my computer?
unfortunately, the voice recorder works only as voice recorder, it cannot play FM and record it at the same time. though you can play fm radio from another device and record it using your SanDisk mp3 player.
To transfer your recordings from your mp3 player, connect your device to your PC.
Open "My computer" from your PC and you'll there "your Sansa Player"
Double-click on "your Sansa Player", then open the "Music" folder, then, open "Recordings" folder.
You'll find all your recordings on that folder.
I have a sansa fuze mp3 player and no user instructions
the menu has these function but you can download most of them from they site
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
9helpful
this should help.
2helpful
Radio won't play
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
I have a sansa clip mp3 but i can't turn on the fm radio. help
Sansa clip - not able to playlist listen on car radio w/ adapter
1helpful
Screen Frozen
HJust hold the off button for 10 seconds. or whenver it turns off. u will be fine
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
