SOURCE: ZANUSSI TC7102W
well its either your belt too slack byt more then likely its your carbon brushes that need changing but to do this u have to take the lid off and then undue 2screws on either side under the lid at the top and the undue the screws around the back panek but there is also 1 on either side of the sides but they are covered by white plastic bungs with a hole in the middle then u can get to the motor to check the carbon brushes m8
SOURCE: i have a zanussi tc7102w drum not turning removed
http://www.wikihow.com/Replace-a-Broken-Drive-Belt-in-a-Clothes-Dryer
This is similar to your model. Buy the belt online or a appliance parts store.
SOURCE: dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
