DEAR SIR,
THIS IS NOT THE PROBLEM CAUSED BY PHONE SOFTWARE OR SOME THING LIKE THAT....
THE PROBLEM IES WITH THE BATTERY AND PLZ ALWAYS USE THE CHARGER SPECIFIED FOR YOUR PHONE AND PLZ DO NOT USE CHARGERS OF OTHER NOKIA MOBILES....BECAUSE IN NOKIA CHARGER PIN ARE SAME,BUT BATTERY MODELS ARE DIFFERENT...........UR BATTERY WILL GET CHARGED BUT THE LIFE LL BE LOWERED.......
THE BATTERY HAS DAMAGED IN YOUR PHONE AND THE SOLUTION IS TO CHANGE UR MOBILE BATTERY.................
It might be a problem with the firmware or it might be a hardware issue also where you have to replace the battery..
I had same kind of issue with my nokia battery first thing nokia suggests or does is upgrading the firmware it hardly resolves the issue..what i will suggest is if your battery is still under warranty replace it nokia saying updating the firmware does no good if battery is out of warranty buy battery from nokia care no where else buy it from them and use it..
good luck
