Question about Polaroid FLM-2632 Television
Proview rx-326 model 3200 lcd tv, has sound, but no picture. . . When powered up the screen flicks on for a split second . . . Is this most likely a micro-fuse on the backlight inverter board? or is it the actual light source? Should I replace the entire inverter board? It goes for about $60. Any help here would be greatly appreciated and thanks . . . . I listed all models with this inverter board in case there are any parallel issues for the models other than my ProView 3200.
SOURCE:
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
SOURCE: bestchef1959@yahoo.com
it's your control board.......Cost as much as a new TV
Posted on Nov 02, 2008
romsky79
  • 822 Answers
SOURCE: screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
Posted on May 05, 2009
  • 4234 Answers
SOURCE: LCD tv powers on, no picture with sound
The problem is not with the inverter circuit. If that was the problem, you would not see the polaroid screen either. The problem is within the video path of the set. This is not a homeowner repair as the ICs involved here are surface mounted and require specialized equipment to replace. You should request an estimate from a local servicer ($50 or so) and report the results here. We can then guide you through the actual replacement of the correct board(s).
Please keep us posted,
Dan
Posted on Jul 06, 2009
  • 70 Answers
SOURCE: polaroid LCD TV Model 3200 - Will not turn on
you have a power supply problem.. I have fixed serveral tvs with this problem. normally you have to replace busted capacitors in the power supply board.
Posted on Aug 24, 2010
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
Digital programming
The RX-326 does not have a digital tuner, only an analog.
Aug 17, 2009 | Televison & Video
No picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
Nov 30, 2008 | Proview PA-32JK1A 32 in. LCD Television
No picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Nov 24, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 RX-326 LCD TV loses BLUE
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Aug 28, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
May 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Polaroid FLM-2632 Television Logo
356 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
