SOURCE: my 9500 next generation treadmill elevation not
Usually its the display panel not sending the proper signal - look under the display panel on the left side if standing on the belt, there is an access opening and there will be 3 plugs or connectors, it is the smaller 2 prong connector, just unplug and replug to clear the connection, that usually fixes mine, while in there unplug and replug all 3 plugs just to be safe.
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: I was cleaning life fitness 9500 hr with an acid
I'm sorry to say that using the acid base solution destroyed your function pad and will need to replace. Any clean must be done with simple green or warm gentle soapy water. Contact Life Fitness1-800-351-3737 or Nation Gym Supply 1-800-496-7278 give Model and Serial Numbers. Either company will help you.
SOURCE: On display stands: MOTOR COMM BAD
Try Carolina Technical Services in South Carolina for all you East Coast guys. They charge flat rate of $175.00 and have a 90-day warranty. Also great turnaround time. Carolinatechnicalservice.com. 864-504-7303. Sure beats sending to California and having to wait for 3 weeks.
