Question about JVC GR-DVL9000 DV Digital Camcorder
The internal Li-Ion backup battery in my camcorder will no longer charge. The camcorder is a GR-DVL9000. What's involved in changing this battery? I know that you will say that this should only be attempted by an expert but this camera is quite old and does not warrant a lot of expense. I come from an electronics background and should be able to do it myself with a bit of help - such as the relevent pages from the service manual. Can you help please?
    Top Expert:
  • JVC Master
  • 29,834 Answers
A Li Ion should last the life of the camcorder.
Take it to bits, find the cell and replace it with exactly the same type and size.
Posted on Jun 21, 2017
5 Suggested Answers
SOURCE:
  • 30 Answers
SOURCE: jvc digital video camcorder gr-d20ek no power
wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
Posted on Aug 15, 2007
satavlad
  • 405 Answers
SOURCE: when I make on my camera GR-DVL9000 i wait
E03 means that ether supply or take up reel is not rotating for more than 4 sec. Could be a mechanical or electronic problem, impossible to determine without looking at the camcorder
Posted on Dec 02, 2009
  • 4 Answers
SOURCE: Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Posted on Dec 17, 2009
  • 102366 Answers
SOURCE: GR-D850 Mini DV Camcorder: need owners manual for jvc gr-d850 mini dv camcord...
http://books.jvc.com/booklist.asp?Model=GR-D850
Posted on Jan 16, 2011
The battery on my Remington MB70 trimmer is no longer hold a charge. Can the battery be changed to perhaps an Li-ion variety?
The charging system in your trimmer is not designed for lithium ion batteries. Installing a lithium ion battery could cause fire and/or personal injury. You should always use the same type battery that came in the shaver originally
Oct 07, 2010 | Remington MB-70 Beard Trimmer
Tip
Samsung SLB-11A Battery
Batteries are very important, here has the best quality products and considerate service
Battery Type: Li-ion
Voltage: 3.80V
Capacity: 1130mAh
Color: Black
Dimension: 43.40 x 31.70 x 7.40 mm
Product Type: Replacement Battery (Brand New)
Condition: New, 1 year warranty!
Weight: 49.61 g
Inventory: In Stock
1. New Generic Samsung i8 Compatible Li-Ion Battery
2. Extra power for your Samsung i8 camera or camcorder
3. High capacity rechargeable Li-ion Battery with premium cells
4. Absolutely no memory effect so you can charge battery at anytime
5. Usually Ships Your Samsung i8 Battery in 24 Hours, 12 months warranty.
on Sep 21, 2010 | Cameras
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
How to charge the is-dv camcorder
IS-Dv does not have internal battery charger, the battery is charged externally using NP60 Li-Ion battery charger ,You can get the battery charger from the manufacturer (Aiptek:)
May 18, 2010 | Cameras
MP4 player will not hold charge
If your MP4 player is 'old' or frequently used and you can use it while being connected to your PC or charger, then the most likely reason is that the internal Li-Ion battery is worned and not capable of holding a decent charge: the solution is to replace the internal Li-ion battery: you have to decide if this is economically viable especially if you cannot do it yourself or the replacement battery is too expensive.
Dec 19, 2009 | Kenwood Audio Players & Recorders
Tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
When I make on my camera GR-DVL9000 i wait 3seconds and a message 'E 03' writen
Dec 02, 2009 | JVC GR-DVL9000 DV Digital Camcorder
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
JVC GR-DVL9000 DV Digital Camcorder Logo
52 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
