There
should be a half sphere-like object on the bottom of the spool where
the line goes. Twist counter clock-wise to remove.
If it is a
duel line trimmer then:
Cut two separate pieces of string,
about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto
spool,
putting the line that is closest to the ground on first.
Once you
have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the
last 4
inches in slot opposite the other locked in piece.
Put the spool
on the
trimmer, feeding the end of lines through either hole on trimmer.
Before
you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer: Then just
wind a single piece of string clockwise onto spool. This may need to be
longer than 7ft.
Jim
