SOURCE: propshaft noise
Propeller (or driveshaft) will transmit noise check the joints at both ends for binding or rust (best done with it out of the car)
SOURCE: Noise from rear wheel area that sounds like bearing noise.
Might want to check your camber adjustments and look into shocks and struts. They could all be worn out but prolly the camber is off causing abnormal road noise and abnormal tire wear
SOURCE: Micra gear box Cv joint relacement
this easy, drain oil from gear box remove that drive shaft (u need a ball joint splitter)
replace gearbox seal, pry out old 1 with screw driver, gently tap new in, oil edge of new seal 1st. replace oil, ps dont leave to long as will damage gearbox when lack of oil
SOURCE: 3L V6 - replaced the front oil seal, timing belt - Belt noise
it usually is the tensioner replace it
SOURCE: I purchased 1500cc NISSAN Sunny 1996 model Car.
20/50 ,cheapest oil and change every 6000mile with oil filter every third oil change ,as for hold back ?=?could be anything under the bonnet causing this
