SOURCE: The recorder will not receive
You may need to check with your provider to see if your cable box is even cable of receiving those channels and that type of content. It may just be that your box is not compatible. Check with them and let me know what you find.
Thanks
Tim
SOURCE: I get no sound or
I'm having sound problems with Gem too, as are others, apparently. If you are getting program info but no picture for either of these, however, I suspect that you may only have a SD digital receiver, rather than a HD (High Definition) one. Can you receive the One HD sports channel? If not, that will be it for sure.
SOURCE: No sound on 90 HD Digital Channel
You need to get in touch with Lg and they will help you. All you need is for them to either post you a usb with software or they can email it to you and you can put it on a usb and put it on your tv via usb port and update the software on your tv.
The frequency for the new channel is not on your tv but they will give you the software to update so it works.
SOURCE: auto tune will only get
please clarify your question in more datail then repost before you can help.thanks
