War craft i have a problem with the screen on my destop monitor. it flickers when i try to start the war craft game. any solutions? the screen is fine on other games and regular internet. my video card is the right kind too.
Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Well here you to go the answer to your problem is.....................................1. Sign out of your playstation account.2. Load game (the game will load fine without being logged in.3. Stop at the start menu do not press start when it is blinking "Press Start to Continue"4. Tap the Ps home button and log on to your account.5. After logging on hit the ps button to return to the game and hit will play fine.
try to use a low version of a driver or download this detonator. it will operate only on some features of your video card it wont push the video card to the limit so that you wont experience any mixing color while playing in warcraft. by the way just adjust the configuration of your warcraft in video so that you will enjoy your game with no hassle. hope that helps!
flicker to which side, horizontaly or verticaly. does it compress from both side or all side. only flicker from sides or from the center also??????????
provide proper information for solution
I would suggest trying another monitor to rule out your PC or monitor card.
I would also check the video settings on the PC.
Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue.
In other words, an internal issue that probably needs component-level troubleshooting.
