I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
3 lights sounds like the pressure switch try jumping it out some times this works , you try and fool the heater,
I put a new switch in. If I tap on the canister as a turn on the switch it will work for 4 to 5 times and then nothing. Any suggestions
Combustion air switch Fail. to close. Any suggestions
check earth connections check hose connections are tight and not split Check connections on pcb board
3 flashes=combustion air switrch failed to close
