SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
SOURCE: Whirlpool Gold Side by Side Refrigerator
sounds like the switch tabs are broken off of the switch bracket behind the dispenser front cover. you should hear a distinct click when you oush in on either lever for ice or water if not then that bracket is broken. if you'll look on the very bottom of disp cover you will see 2 slots insert a small flat blade screw driver and pry the cover off then you'll see a white bracket with switches and wiring on it look at the black switches and most likely the little plastic posts that hold them on are broken. the bracket is inexpensive and very easy to repalace. if you have any urhter questions just ask thanks peyton...
SOURCE: refrigerator whirlpool gold side by side light in
Could be the light switch on the inner wall that the door closes against
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
