No outside temperature just shows the temperature outside the car the snowflake symbol will not show up until it is cold enough outside it has 2 stages yellow is an initial warning of cold temperatures when it gets to freezing the symbol will turn red.
The outside temp warning is not connected to anything mechanical only the engine temerature gauge is so dont worry it will not affect the running of the car but is just there as a warning of falling temperatures outside.
If you
just want to use your bean bag for sitting occasionally outside, you can use
your regular one, just make sure to bring it in when you are finished or it
will get ruined. But if you want bean bag chairs to stay outside, you need to
buy one that has been made for that purpose.
The ambient lounge website has a massive range http://www.ambientlounge.com/
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
