Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
Posted on Sep 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the defrost timer located on hss251fmb ww
John Tripp
Level 3:
  • Hotpoint Master 4,656 Answers
  • Posted on Sep 24, 2011
John Tripp
Hotpoint Master
Level 3:
Answers
4656
Questions
Helped
1678831
Points
14883
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Sep 28, 2010
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
36636
Points
338
There is no defrost timer on this model. Defrost is controled by the main board. There are four things that will cause a defrost problem with this refrigerator and they are the main board, the defrost thermostat, the defrost heater and the evaporator thermistor. This page will help http://appliance-repair-it.com/GE-refrigerator-repair.html
2answers
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Location of defrost timer on hotpoint hss25gfph ww
The defrost timer is part of the main control board located on the rear of the unit. Here is the new updated board for that unit.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
My recently acquired used hotpoint refrigerator model number hss251fmb ww freezer side freezes sometimes but at times it just refrigerates, the refrigerator side almost never gets cold....(enough...
I would check for ice build up in the freezer area. Take the food out, remove the shelves and then remove the 4-6 screws to take the inner back panel off and take a good look for ice. The defrost assembly might not be working if you have an ice build up.
You also need to see if the fan is working or not.
You can either let the unit sit with the door open and defrost naturally or use a hair dryer to speed it up some.
http://www.partselect.com/ModelFrames.aspx?ModelID=379769&ModelNum=HSS25IFMBWW&mfgModelNum=&ManufactureID=2&Selected=00113066i06&Position=5&mfg=GE&Type=&Mark=3
2answers
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
1984 panasonic fridge defrost timer
That panasonic model number doesn't come up in my parts catalog.But defrost timers are pretty generic.Most refers in that era use the same timer.Locate the timer and remove it.Take it to any appliance parts store and they can surely match it up with a universal timer that they have in stock.Cost is less than 25.00.
1helpful
Freezer side of refridgerator doesn't freeze foods properly and also makes only about 10 cubes a day. food side works fine, it's a Hotpoint model #HSS251FMB WW
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
1helpful
Freezer not freeaing
the suction pressure should not be less than 5-10psig
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
