Here is the Schematics, large file
http://www.mk-electronic.de/Hersteller/PDFDokumente/Samsung/Color-Multifunktional/CLX-3160FN.pdf
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
