i've bought a new Jabra BT350. As the manual, I put the AC charger into my headset. It suppose to give the red light, indicating it is being charged. But it didn't. Is it broken and i have to return it?
Please help me out. Thanks.
Victor
Right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
Make sure your adapter isn't in upside down. It fits both ways.
It is possible to have a defective earphone. I have seen this a number of times.
Jerry G.
same problem here. i opened the package and tried to charge it. in a second, it had green light, then turned red, then the light turned off, but no charging light.
red light comes but it doesn't hold a charge
I just bought a new Jabra BT350 Bluetooth Headset and tried charging it. No light comes up and when I called Jabra they said it is a old model and will not be able to replace it be'cos it is 3 years old model. I will have to buy another one and end up losing the money on this one.
After plugging in there is not light. doesn't charge
the same problem here.
Is this piece designed to die? Even if it is an old model, but brand new earphone should still work. Jabra technicians, please explain...
Less than 10hrs on this headset...Now i plug it in and the red light stays lit, no charge. Jabra is cutting edge??? I don't think so!
I have had my Jabra BT350 for about a month, and when I go to charge it, I get a very faint red glow from the indictor LED. It doesn't turn green after leaving it the charger for over a day I have doubled and tripled checked the AC adapter is plugged in the correct way. I even used different electrical recepticals to make sure there wasn't a bad outlet.
same problem, it shows me a red then a green for a quick sec and then just dies, when i plug it in.
i have 2 models bt150 and bt350 same problem with both !
defective !! ??
two brand new out of box same problem...cannot charge battery..jabra tech support isn't interested
