Question about Kenmore Elite 21082
GETTING AN ERROR MESSAGE OF FL, WHAT DOES THIS MEAN?
  • 699 Answers
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue.
Restart the machine machine as required or push the overfill reset switch.
To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed.
Hope it helps let me know how you go.
Posted on Sep 28, 2010
SOURCE:
What is mean error code FL
Error Code F8 E1, LF, or LO FL all indicate that no water is detected entering washer after 13 minutes. ... If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive.Apr 24, 2018
F8 E1 or LF or LO FL Error Code in Display - Whirlpool Home ...
producthelp.whirlpool.com/.../F8_E1_or_LF_or_LO_FL_Error_Code_in_Display
See the videos
error code FL Google Search
Jun 11, 2018 | Washing Machines
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Receiving error code FL on washer display.
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Dec 07, 2012 | Crosley CW6000 Front Load Washer
Samsung WF350ANR/XAA has an error code FL and door will not lock to start cycle
The FL Code means that the door failed to lock. Turn the machine off and restart the cycle. If this does not clear the error message and the machine does not return to normal, you will need to contact a Samsung repair service.
Jul 25, 2012 | Samsung WF337AA Front Load Washer
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer will not drain, and gives a FL message.... It will not reset... How can I fix it?
Flood Condition:
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Whirlpool calypso top load washer getting FL error message
fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Jan 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code FL
FL means the door Locking Mechanism has failed. It will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2008 | Washing Machines
KENMORE ELITE CALYPSO
Call Kenmore if you bought it new they may have a record of your serial number and be able to tell you what the error message means and if you need a service call to fix or you can do it yourself. my serial number is on the back of the washer on a sticker or a typed silver tag that is attached to the washer.
Oct 03, 2017 | Washing Machines
Washing Machines Logo
99 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
