This could be from a couple things, first is that as units get a little older, the drains and pans start to clog because as your removing water from the air, your also removing dirt. Sometimes this dirt builds up on the bottom of the pan and over time, it clogs the drain. This will allow the pan to overflow and spill over on the side that has the lowest spot. One way to tell is to shim up the back about an 1/8th or an inch. If it leaks from the front now, your drain is clogged. If it drains fine and the drip in the back goes away, you have corrosion in your pan and you'll need to take it apart an clean it, aluminum tape it, and silicone it to get back to full operation.
