Julie I don't have a replacement key but if you contact Golden Tech @ 800-624-6374 or e-mail the parts dept @ [email protected] give them the serial number and they can get you a key. Now if you stuck for funds like alot of us you can purchase a on/off toggle switch for about $3.00 and replace the switch with the toggle switch. You have to take the tiller cover off to get to the old switch remove it by cutting the wires and attach the 2 wires to each pole on the toggle switch. Once you have the wires attached to the toggle switch turn it on and off to make sure it works and then insert it into the old switch hole tighten the nut to secure it to the cover and put the tiller cover back together. Good luck Hope this helps you
SOURCE: I need keys for scooter
Hi. Some brands of scooters use the same key for the same models, one key fits all. See your local dealer about this.
If your machine has keys that only fit your machine, the best way is to replace the complete lock, and get spare keys cut.
If this is too expensive, remove the complete lock, and take it to a good locksmith, they will be able to cut new keys to fit your lock. You can then fit your original lock back in your machine.
Good luck. Neil.
