SOURCE: Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light bulb.you can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
SOURCE: Blub brightness has dimmed.
Replace the Lamp unit is the best solution. that will cost you around $450.
Viren
SOURCE: blurring
Check if it is not the same problem as http://www.fixya.com/support/t401456-infocus_x3_video_problem
SOURCE: optoma projector switches off after 5 mins
AS regretable as this sounds component failiure was my first thought .. It's not the bulb temp sensor as the fan is opperating and that usually cuts all power .
You may find that as you have a bulb ( usually worth more than the units they reside in ) rather than a repair another unit of Ebay would be a safer and more economic conclusion ... Regards Vortash
SOURCE: optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
