If the incline motor does move, try the calibrating process. Call ICON for step by step procedure. If it won't calibrate properly, pull off the cap that has a black wire going to the controller board. You can gently pry up with a small flat blade screwdriver. Pull out the wire with the motor sensor at the end and clean off the oil on it. It may have too much that prevents the sensor from seeing the motor movement. Last and more difficult way is to manually adjust the motor shaft position. Turn the treadmill on its side. Remove the pin and bolt that goes through the plastic belly pan. Be careful that if the deck swings about, that you don't get your hands or anything hit by it. Now you need to turn the motor shaft to a new position and reassemble and see how it sits. You may have to do this several times until you get it where you want it. Important to know: The machine will slam to the floor if you don't turn it on its side to work on it and have the motor bolt inserted when standing it upright. You would hurt yourself.
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
