Question about LeapFrog FLY Fusion Pentop Computer
Powering on My fly pen does not turn on at all. when i press the button that is supposed to turn it on, it flashes green, then turns off. also, when i plug it in to the computer, it stays red and never turns yellow, even when i press the power button.
  • 8 more comments
  • Kelsey G Jul 21, 2008
    My FLY Fusion Pentop Computer has the same problem that maxxman's is having, except for one thing. It will not turn on, it only flashes green when I push the button, and then turns off, and when I plug it into my PC, the light is a steady red color, until I press the button. When I press the button, it flashes red and yellow, but STILL DOES NOTHING. My FLY World application on my PC will not detect it or respond to it. Help!
  • Anonymous Sep 17, 2008
    same as others
  • redheat Sep 17, 2008
    when I turn my flypen on, it flashes green then shuts off
  • Anonymous Dec 17, 2008
    Exact same thing for me! I'm very mad because I got it for my birthday yesterday and it just stopped working for me!
  • Anonymous Dec 30, 2008
    except, mine doesn't flash or even turn red. its just black. what do i do???
    help pleaseeeee
  • newnew631 Jan 01, 2009
    i have the same ******* problem... and i paid one hundred dollars for this ******* pen ..i need some kind of assistance..
  • Anonymous Jan 02, 2009
    it just happened to me too. what the heck.
  • mthomtech Jan 02, 2009
    I have the same problem. When plugged into the computer, I get a red light ... sometimes flashing. When unplugged, I can see a very faint green flashing. No response from the fly world app, no response from notebooks or anything.
  • Anonymous Jan 04, 2009
    mine wont show any color and doesnt show usb port connection on the screen??
    Any ideas?
  • Anonymous Mar 18, 2014
    My fly pen isn't turning on at all! When I press the button it doesn't do anything. Do you have to do anyhting before turning it on? It's my first time using.
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
Posted on Jan 02, 2009
SOURCE:
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
The stylus pen does not work
You can try calibrating the stylus pen. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Jan 20, 2011 | LeapFrog Enterprises Leapster2 Learning...
After charging our green Leapster 2. We turned it on and it won't allow me to get past name selection. It wont select the specified name. Its like the pen isn't working anymore. Can this be replaced?...
You can try calibrating the stylus pen before trying to replace it. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
6) Restart unit
Jan 13, 2011 | Leapster 2
I have a Daenyx TV- model DN402, bought it in April of 2008. All of a sudden the TV Is having issues with powering up. The green button responds to the remote and TV button only flashes green which is...
If you are pressing the power on button on the remote, you might want to try replacing the batteries, and make sure the contacts in the remote are clean and not corroded. With some remote controls a clear line of site is needed from remote to TV sensor. You might try moving closer to the TV to eliminate the possibility of an obstructed line of site. If the remote sensor is optical there may be dust covering the sensor and diminishing the signal. clean it with a soft cloth and maybe dampen with windex.
Oct 04, 2017 | Televison & Video
Printer error code 5100
I got error 5100 after a paper jam. There was a small piece of torn paper stuck in the gears, and I had to mess around and move the print cartridges back and forth to get seated back on the ink pads to the right of the printer (if you're looking at it from the front).
Reset the printer by powering it off for 10 seconds and try to repeat a test print.
I was able to get mine to work after a few tries. Good luck.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
let me know if this is helpful to you
Dec 09, 2009 | Canon Office Equipment & Supplies
5100ERORRS
If this does not work for your model revert back to me along with your model number .
1. Turn off printer
Jul 25, 2009 | Canon PIXMA MP180 All-In-One InkJet...
The fly pen is not turning on
it just has to charge. whn i turns d its charging. leave it for 15min andn take it out and turn it on. if it doesnt tn on contact an expertfrom the place u got it.
Jan 01, 2009 | LeapFrog FLY Fusion Pentop Computer
Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
LeapFrog FLY Fusion Pentop Computer Logo
657 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
