I purchase a ONE FOR ALL Universal remote for my samsung TV but none of the codes work. The model number for the TV is CS-29D4V.
May not be the same thing but I have a Samsung Hitron Black 20" CRT and the following programmed the sky remote...
Press TV on the remoet, hold down select and red until the red light on the remote flashes twice (about 2 seconds). Key in 615 and press SELECT. Job Done.
Cheers,
Mackem
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Kindly close this thread with a “Fixya” rating if you have been able to
fix the problem, so that I can remove it from my work queue.
If the issue is not resolved, please post back with latest developments, what
steps you took, etc. and I will assist you further as best I can.
Thank you for understanding,
IrishDruid
i need the remote control code for samsung hitron tv model no .CB-14D8V2X thank you .my email is [email protected] PLZ send me sir/madam
Please check the bellow link related to your issue:-
However these are the Remote Control Codes for different Samsung Models:
With the TV in standby, press the
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
To exit, simply Power Off the TV.
Well i tried these codes on my SAMSUNG HITRON 21" CRT TV but did not worked. however at last i tried :
{DISPLAY}{MENU}{MUTE}{POWER}
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Thanks very much I tried everything but they did not work at all.
i need the remote control code for samsung tv model no .thx 1970 thank you my email is [email protected]
I have a samsung TV, LN26R71, and the codes described in the manual to operate a Home Theater of SONY, cable tv digital for net rio doesn' t work at all.
Samsung doesn' t give a **** totheir clients
onn universal remote auto search for samsung tv
all of a sudden the to tv wont respond to the cable remote and the Samsung remote.Put fresh batteries and still no better.
