This article is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown.
Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence.
CAUSE:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
- Mismatched system files have been installed.
- A Service Pack installation has failed.
- A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
- An incompatible third-party program has been installed.
Resolution will not fit here so kindly go to:
http://support.microsoft.com/default.aspx?scid=kb;en-us;156669I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
