Question about Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302
How to change heating element - Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302
  • 349 Answers
Cut power off and take off cover to reveil element with number on it's side to give you info to get another one rated the same to go back in.
Make sure power supply is off to water heater and then turn water off to water heater. Then open a faucet's hot side and connect a water hose to drain and drain down water out of water heater to keep from getting water on floor. After heater is drained you are now ready to remove wires and element with a socket 1 3/8 "..
Replace new element in place and turn water back on and fill heater back up with all air out of system before cutting power on. Once air is out and water running from all facuet's hot sides throughout house now you can turn power back on.
One more thing when draining tank if it doesn't want to drain good open lever on relief valve to allow water drain faster.
Posted on Sep 27, 2010
SOURCE:
IT doesn't heat up any more so the towel does not get warm, do you know anything about towel warmers? do they have an element?
Many do have an electric heating element; there may be a light next to the switch which might indicate whether it is on or off. However some are heated by hot water or steam (it seems). You might consider changing the element, try the fuse in the circuit first, it might save you a lot of trouble. If you decide that are able to change the element yourself, get the instructions and only then source the part. If it's wall mounted it's more difficult. However it's probably best to get an electrician to do it as it can be very tricky. I may even be necessary to contact the manufacturer or buy a whole new item
I hope someone else comes up with a better answer !
19.January.2016
Jan 19, 2016 | Mr Steam W542 Heated Towel Warmer W542...
Our Titan N-120 stopped heating suddenly so they suggested we change the elements. My husband bought 2 elements but apparently he didn't realize 1 is 5000W and the other 5500W. Now could this stil
the bigger wattage elements will heat quicker and consume more power
If they fit , they will work but you may have to check the amperage capacity of the circuit breaker
I imagine you are meant to replace the existing elements which woukd have been half what was purchased
Mar 06, 2018 | Water Heaters
Hello - I have a 6-7 yr old Whirlpool EnergySmart 50 gallon 5500 watt water heater. (Two control boards fried and were replaced free). Symptom now is not enough hot water. No 'error codes' are blinking...
1) Residential water heaters are non-simultaneous. Only one element works at a time.
Upper element comes on until top of tank is heated, and then lower element is switched on until lower part of tank is heated. Lower element keeps tank hot during standby hours
http://waterheatertimer.org/How-it-works.html
2) Typical Whirlpool energy smart has 4500Watt elements. Look at label on side of tank
If both elements were ON, that would draw 9000Watts or 37.5 amps, requiring 50 amp breaker and 8 gauge wire. V x A = Watts.
All dual-element tanks are 240V.
Whirlpool energy smart requires 10 gauge wire and 30 amp breaker so electronics are not starved during operation. If your wire or breaker are undersized, that is suspect for repeated failure.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Typical electric water heater heats 21 gallons per hour. First hour delivery is higher since elements heat water as you use it. Overall however, electric water heater cannot re-heat as fast as gas because gas water heater burner carries more BTU punch per minute than electric element. Gas heats about 41 gallons per minute, with higher first hour delivery.
4) IF YOU HAVE OLDER energy smart and installed newer board, then you could have non-simultaneous operation is reversed so that lower element comes on first.
Read following post at Fixya:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Contact Whirlpool 1-877-817-6750
5) Another potential problem is that you have sediment inside tank and that is reducing efficiency of lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 09, 2011 | Water Heaters
The electric element doesn't work.It has power to the plug in but does not heat. The gas works fine. Where is the heating element on the tank?
It will be on back side of water heater, follow hydro wires into metal or plastic cover. (shut breaker off before proceeding) remove that cover and you will find element. Double check thermostat and ECO for tripped reset switch (little button in center of it) while cover is off as well, before going through trouble of changing element.
Jun 29, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
How do i change the element in my water heater
The most important step is to turn the power off. If you still have the manual it is the best to follow the instructions provided in a book.
If not, learn about electric water heaters, how to test the heating elements, how they work and are they OK, than follow the instructions:
Once the power is off, turn the water supply off, attach the hose and drain the water heater.
Unscrew the terminals from the heating element and unbolt the elements from the water heater.
New heating elements has to be with same specs as the old one.
Before turning the water heater on it is VERY IMPORTANT to refill the tank.
Mar 21, 2010 | Reliance & 50gal Electric Water Heater
I have change the bottom heatern and the bottom thermostat but the bottom heate do not have current even if the top heater and thermostat have current.
There will be no current to bottom element until top element shuts off. then top thermostat will send current to bottom element only after the top half of the water heater has heated up and shuts off current to top element. Only one element at a time can be on. If current still does not go to bottom AFTER top element shuts off, the top stat could be bad.
Dec 28, 2009 | Water Heaters
Voltage varified correct to top thermostat
change the thermostat on both upper and lower elements, and the elements depending on the age of the water heater, if it is over 6 years old consider changing the water heater,
May 06, 2009 | General Electric GE SmartWater Household...
Changing heating Element
1-800-325-9250call this number and they can tell you what you want.
Apr 29, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302 Logo
135 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
