I have jabra 125 bluetooth headset, but its support part that holds against the ear has broken, so how i fix it? i am not able get the part anywhere here in bhopal or in the vicinity......
I would charge it using anohter charger, or through the USB into the computer if available. If it still holds a charge for so little time then call jabra for a warranty replacement,
In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
You will need to pair it with your phone. first make sure the headset is off, then put the headset in pairing mode by pressing and holding the answer/end button until a solid blue light appears. then you will need to goto your cell phones bluetooth menu, turn your bluetooth on, then in your bluetooth menu you will need to add a new device or discover a new device depending on the type of cell phone you have. Your phone should find the jabra ear piece if it's in range of your cell phone and will ask if you want to pair with the device, after accepting confirm with the pin of 4 zero's.
It's kinda cheesy, but a piece of #10 wire fits perfectly into the hole. That's what I'm using now. Neither the original is very comfortable, but they work.
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
