If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
bottom right( red wire 12 v dc on/off ignition switch) 2. top right( blue wire with inline fuse to amplifires) 3. bottom left( black wire ground) 4. top left( blue wire stereo remote wire)
top left - orange.....goes to aux or memory wire top right - blue.......goes to the remote wire used with amps bottom left - black.......goes to the ground wire bottom right - red........this goes to your hot wire
Blue goes to your head unit's blue wire. It switches the eq on when the head unit is switched on. It also gets tied into the amp's blue wire (if you are using an amp, and I guess you are since you have a passive eq...). The fact that there are 2 is just for conveinience I think (99% sure) If I recall one may have a white stripe, and the other none. If you want to be sure, with all power DISCONNECTED to everything, and the harness plugged into the EQ, use a multimeter to see if there is continuity (connection) between the 2 blue wires. Then you can rest assured they gave you a secind one just for a "pass thru" to your amps, but inside they are electrically connected, and are essentially the same piece of wire.
