I have lost the manual for my NTL VS205 it has a built in answer machine and when u call the home number it wont let u leave a message so i need to change the settings for this can you help? Drew
SOURCE: NTL VS205 lost manual
There are two types of messages you can record onto your answer phone.
Type 1 plays your message and allows the caller to record their message for you to hear.
Type 2 plays your message but does not allow the caller to record a message.
To add your own type 1 outgoing message (OGM1) on the answer phone use the following proceedure as outlined in the manual.
From the VS205 handset
1) Press the clear/mute button - display = "TAD ON"
2) Press the 9 button then the 1 button - display = "91"
3) When you hear a beep speak your message into handset.
display = "REC OGM1". Note:- 30 seconds maximum.
4) Press 5 to stop the recording.
Your message will then play back to you.
display = "PLAY OGM1"
5) At the end of playback there will be a double beep.
The display will return to "TAD ON"
To Play/Check OGM1
1) Press Clear/Mute. Display = "TAD ON"
2) Press 6 then 1. Display = "PLAYOGM1"
Your OGM plays back inviting the caller to leave a message.
Note - To restore the pre-recorded OGM1 press "0" (Zero) at any time during playback. The display reverts to "TAD ON"
To add your own type 2 outgoing message (OGM2) on the answer phone use the following proceedure as outlined in the manual.
2) Press the 9 button then the 2 button - display = "92"
display = "REC OGM2". Note:- 30 seconds maximum.
display = "PLAY OGM2"
To Play/Check OGM1
2) Press 6 then 1. Display = "PLAYOGM2"
Your OGM plays back but should not invite the caller to leave a message.
Note - To restore the pre-recorded OGM2 press "0" (Zero) at any time during playback. The display reverts to "TAD ON"
Hope that helps.......
ive lost the manual for my ntl vs205 phone and cant seem to get the answer machine to work
Have lost maual for VS205 - unable to leave any messages - callers get reply "unable to leave message please call again later"
i have the same problem message "can not take your call or leave a message"
Hi, I have exactly the same problem, can you tell me if you managed to get a new manual?
Soneya
i have recently got these fones second hand and i dnt no how to access the messages, answer phone if any on knows how to do this if they could email me [email protected] they are the ntl vs205, many thanks. i haver spent hours looking for a manual online but still ain can across one
Bought these phones, but they didnt include anything on how to use them
I have the exact same problem.
i have not manual and for some reason the handset is registering messages and i dont how to access them. please help i ahve tried all sorts of combinations
lost manual for vs205 unable to reset answer phone system
