Question about Dryers
Reset button Where do I find the reset button on a whirlpool electric dryer?
  • 2 more comments
  • yoo1 May 23, 2008
    Where do I find the reset button on a whirlpool dryer?
  • Anonymous Jul 03, 2008
    Does anyone know where to find reset button on kitchenaid dryer
  • Anonymous Aug 08, 2008
    My dryer just started beeping one night, and I tried pressing the bottoms to make it stop but it wouldn't. So, I unplugged it and replugged it. Now it won't come on.
  • althauser Jan 30, 2009
    e61 error code
Where is reset button on amana dryer
Posted on Dec 21, 2008
SOURCE:
Whirlpool dryer won't heat
Check the back of the machine to see if there is a tiny red button. This is a thermal safety cut out button, which you may need to just press to reset
Dec 26, 2013 | Whirlpool Dryers
My whirlpoolduet dryer is on control lock how do I unlock it model # gew9200lw1
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Whirlpool GEW9200L Electric Dryer
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Electric whirlpool dryer
have you a reset button on rear panel normally red press it in if you have and make sure filter is clean .DO this with DRYER turn OFF.
Feb 11, 2010 | Whirlpool LEW0050P Electric Dryer
Is there a reset button after heating up and
Not sure about your model.
Look on the motor, sometimes there is a reset button on the motor.
Sep 25, 2009 | Whirlpool LER4634J Electric Dryer
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer problem
try pressing the End of Cycle button on the far right for more than 3 or 4 seconds.  It should reset.
Dec 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Dryers Logo
1,239 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
