See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website.
And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
http://www.ehow.com/how_6730072_change-bike-grips.
html Bike grips and stroller handles work the same way.
I just used this post on e-how to replace my maclaren triumph foam handles.
Works like a charm - and it's sooo easy!! :)
Thank
you for posting your question here on Fixya.com.
Purchase
a can of spray foam insulation and then drill a hole in each end of the handle
to match the spray tube on the insulation. Let the handle dry once the holes
are drilled then fill the handle with the foam from one end until it begins to
expand out of the holes. Once the foam has set you can trim off the excess and
scoop out a dimple of foam from each of the holes. Seal the holes with a
two-part epoxy but even if the handle still leaks the foam will prevent much
water from getting in and the handle will remain buoyant.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated
once your problem is solved!
John
