Question about Hotpoint Ultima WF860 Front Load Washer
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
  • 118 Answers
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Posted on Sep 27, 2010
6ya staff
SOURCE:
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Hotpoint ultima tumble dryer
    sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
    Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
    Timer counts down too quickly
    Possible there is fault in the timer unit . check for loose connections or loose joints to the unit, if not this needs a replacement.
    Jan 12, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
    My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
    Error code E30 indicates motor tachometer failure.
    There is a loss of signal during tumble or spin.
    Check your user guide.
    Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
    My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
    Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
    Please leave feedback.
    Thanks.
    Nov 12, 2009 | Hotpoint Dryers
    My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
    F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
    Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
    Hotpoint Ultima CTD80
    i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
    Sep 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
    Hotpoint CTD80 Tumble Dryer F03 error
    hiya
    sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
    hope this helps
    please dont forget to rate the helpfulness of this reply, thanks kj.
    p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
    Jul 24, 2008 | Hotpoint Aquarius WD63 Front Load...
    Hotpoint ultima tumble dryer error code f-03
    Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
    Hotpoint Ultima WF860 Front Load Washer Logo
    384 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Eric Taylor
    James Hehling
    James Hehling
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
