Question about Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw
Sthil fs45 cuts out when squeeze trigger - Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw
    Sergeant:
  • Stihl Expert
  • 417 Answers
You need a new carburetor.
Posted on Nov 23, 2013
SOURCE:
How do I get this tool apart to clean it.
Think you need to replace the motor brushes. As they wear they get shorter and the spring that pushes them up against the commutator is now at the end of its travel. Replace brushes or stretch the spring a tad.
Feb 14, 2016 | Saws
How to adjust my throttle cable on my backpack blower br 550 sthil
the cable has streched out
you may need to shorten it to get an adjustment range
you could always look up the manual
it tells you how to do this in it
Nov 30, 2013 | Stihl Br 500 550 600 Backpack Blower...
How to change the cutting line in a curved shaft fs45 *******
No, I'm not sure why STIHL even makes curved shaft trimmers at all. I have never worked on ine in 10 years of being a STIHL tech, I just throw them out when they don't work and steer the customer to a straight-shaft. It's their punishment for the mistake of buying the curved shaft in the first place.
May 04, 2012 | Stihl Fs45 Trimmer Drum Sprocket 45 55 46
How do i set up the carburetor on a sthil ts400
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
Feb 24, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl FS45 will not run at full throttle
replace fuel filter in the tank and will be fine it is gummed up .stock part at any sthil dealer
Aug 22, 2009 | Garden
Engine starts cuts out when trigger squeezed
plugged fuel filter or bad gas
Jun 27, 2009 | Garden
Stihl FS45 2 cycle string trimmer. Bought in 5/06 Cutting head came off while cutting. Flexible shaft still has squared off end so it doesn't seem to be broken. What holds the cutting head shaft with the...
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Jun 22, 2009 | Garden
Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw Logo
130 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
