Hi there ,
It is possible to connect this phone (E1410) to the PC for Internet facility. You just need a bluetooth device.
I have successfully done it on my Airtel sim card using MO (Mobile Office) package.
Follow these steps-
1. Don't call the Airtel Customer Care to activate Mobile Office Setting. Because they will tell you that your handset does not support automatic MO setting.
2. In your phone go to browser and go to Browser Settings
3. Create a New Profile with the Name- Mobile Office
4. Home Page- http://www.google.com
5. Set the Proxy as- 202.56.231.117
6. Set the Port as- 9201
7. Bearer- GPRS
8. Go to Advanced Settings and type the APN- airtelgprs.com
9. Log in ID and password no need.
10. Recharge your your phone with any GPRS (Mobile Office) packages Rs.22 (200MB)/ Rs. 98 (2GB-30 Days validity).
12. From your mobile dial *567*11# (This is must)
13. Now your MO is activated. Now turn off your Phone, Remove the Sim card and turn on again.
Please cancel the mCheque msg. if it appears after restarting your phone.
14. In your PC -Install the Bluetooth Driver.
15. Right click on the Internet Explorer-Properties-Connections
16. Select the Bluetooth DUN Connection
17. Click on Settings
18. Set the proxy-202.56.231.117 ;port as-9201
19. Click -OK, Apply - OK.
20. Now go to control pannel and double click on Phone and Modem options.
21. Click on Modems tab.
22. Select Bluetooth DUN Modem
23. Click on Properties
24. Click on Advanced Tab
25. In the Extra Initialization Command box paste the following command line-
AT+CGDCONT=1,"ip","airtelgprs.com","",0,0
26. Click OK, then Apply-OK.
27. In your phone turn on the Bluetooth
28. Insert your Bluetooth Device in Your PC and connect Your phone through the Bluetooth software
29. Click- Bluetooth Dial up Networking Service on your Bluetooth Software
30. The dialing number is *99#
31. Remember the connection may not done for the first time. So you may need to try more and more. Because the Airtel lines are always busy. Sometimes you may need to unplug your Bluetooth device and
exit your BlueSoleil from the Quick Lunch bar and Restart the Procedure. Remember this is the only procedure
for Airtel (MO) users. Try and Try and if it is connected the open any browser (I prefer- Mozilla Firefox) and open- www.google.com. Remember in some cases, it shows a false connection and the website will not open.
In such cases, Disconnect your Dial Up connection and Re-connect it. If any message apper in you phone, then exit it.
32. To check Mobile Office Package balance and validity dial- *123*10#
32. Remember I am sending this information to the internet via Connecting my E1410 mobile to my PC using Bluetooth device.
33. If you are successful, please say a little word-"Thanks
