Also make sure that your needle is oriented properly for your machine or switch it if you are not sure. The flat side needs to either go to the left or right, depending on the machine. It also could be your tension out of whack so try tightening your upper thread tension. One third thing is make sure that your needle is threaded absolutely correct. Blessings!
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
