Question about Xitel Audio Players & Recorders
Downloaded program, got a menu hooked up the cords then got a message= LP Recorder has terminated can't find audio output mixer line for line in (Realtek AC'97 Audio) (0047C6F0) Ive had this software for about three years and just opened the box and tried to install it. I have ver. 7 windows Richard
SOURCE:
  • 55 Answers
SOURCE: my audio card
Hey its is problem with drivers
Please follow the steps to resolve :-
1)Download the UAA drivers first from microsofts site
2) Download the Latest drivers from
http://www.realtek.com.tw/
PCI drivers + Latest Audio drivers
3) windows installed 3.0 / 3.1
4) now go into Add / Remove programs and uninstall the previous version on Realtek drivers also remove windows installer if available
5) now restart your systems
6) Now installe the windows installer first -> restart
7) now install the UAA drivers -> Restart
8) now install the Realteks latest version -> restart
If it does not solve your problems please do reply i have other trick too..::.. :-)
Posted on May 30, 2008
  • 31 Answers
SOURCE: need toupdate audio driver. Realtek AC97 Audio for VIA R Audio Controller
This is where you can download these drivers. Hope this helps.
http://www.softwarepatch.com/utilities/ac97-realtek-driver-vista.html
Sincerely,
cdixon18
The Man Inside The Machine
Posted on May 19, 2009
Geekman
  • 32281 Answers
SOURCE: Hi There Ive Got A lenovo l-nc51m motherboard
This is a hardware driver problem.
The final version of Windows 7 has not been released yet, you most likely have the RC copy of Windows 7 (ie Release Candidate - final beta version just before official release) the RC is available to anyone to download and test.
The problem is that not all device drivers are avaiable and if you cannot get a Windows 7 version audio driver from the manufacturer's WEB site at this stage, you have to wait until it is available.
Posted on Aug 30, 2009
  • 1738 Answers
SOURCE: Windows 7, HDMI output, realtek acl888, abit
I would back to windows vista or windows xp. Everytime MS release a new windows they always have drivers issue with audio and printers.
Posted on Nov 09, 2009
ziggy12
  • 105 Answers
SOURCE: windows 7 drivers for ac-97 audio
JUst use vista driver..it will work
Posted on Dec 14, 2009
How do connect my cd recorder to my mixer and amp
U connect the recorder to the audio outputs of mixer. If you only have one set of outputs, get a y adapter and have one set of outputs go to the recorder and other set to the amp.
Sep 02, 2017 | Audio Players & Recorders
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
This is not a solution. i have just discovered that I have exactly the same problem.
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
"Cant' find audio output mixer line for Line (USB Audio)(0047C6C0
I got this error when first running version 5 on Windows 7. So I tried running it in Windows XP SP3 compatibility mode, which solved it for me.
May 31, 2010 | Xitel INport (HFLI1X1) Audio Input
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Feedback noise from mixer
Your mixer is already grounded, and does not need any additional grounding. It is grounded through the Power Cord.
Now, the feedback might be coming from one of the units you have connected to the mixer. The issue could also be the cable you are connecting to your recorder. Are you recording to a computer, or to some other external recorder (CDR / DVR / MDR, etc?) - try a different cable. Also try the different outputs on the mixer - you have 2 balanced line outputs you can record directly from. Don't use the RECORD OUT line, it's an unbalanced line, and if you want a good quality signal to record, your best bet is to use the XLR outputs. However, that might be connected to your amp or something.
What do you have going to the unit? Disconnect everything, and try by connecting each item 1 by 1, to eliminate where this feedback is coming from. Also, check for any ground loops that you might have, if you have a lot of equipment hooked up in your set up. (Educate yourself on Ground Loops)
If all else fails, get yourself a HUM ELIMINATOR.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
49 people viewed this question
Top Xitel Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xitel Audio Player and Recorder Expert? Answer questions, earn points and help others
