It is recommended to try putting the machine into diagnostic mode. If it won't enter
diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Let me know how this goes and whether you need any further help
good luck and please let me know if you have any questions when doing this
Press the end of cycle signal- button for 3 seconds and it should work..
If that doesn't help, try Control On + Pause/lock + Temperature for 5 secs
If none of the solutions worked, you will probably have to replace the control board..
i cannot run diagnostic since "Control On" green button will not even come on. the system is stuck where ONLY the red light for "Control/locked" is on.
my 2 year old son probably pressed all the buttons in some sequence to lock the system. Please start over with the help.
pressing all three buttons together did not help. it did bring up the lights for the timer at :50, Heavy Duty light flashing,hot cold light, high and louder. Control/Locked is still on and nothing works
