Proton MM2701VT 27" TV Logo
Posted on May 22, 2008
Magnavox MS3252S431 The screen on my 15 month old Magnavox model MS3252S431 (chassis L01-1UAC-7638) 32-inch TV goes blank with a clicking sound. The green power light stays on. If I power off the TV and then power on again everything is fine.... sometimes for a few hours, sometimes the problem occurs again in a minute.I change the R3340 but still same problem plus first the volume bar will appear and sometimes lower the volume by itself. then the main tv menu will appear on its own and randomly move thru the menu. the 3rd stage is it will do all of this.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
592
Points
7
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
NO PICTURE ON MY TV BUT I DO HAVE SOUND.
Check all your cables, make sure CRT boards are tight. Make sure you put the black ground wires back on the tubes. Also make sure that no fluid has spilled on the circuit boards.
1helpful
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
2answers
Junk from magnavox.
Trying unppluging wait one minute and plug in again.
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
4helpful
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
1helpful
Magnavox 32" tv ms3252s431 shutting off
Usually, the L01-1 chassis most common problem = weak
capacitors, such as C2455.Could be C2425......47mf/25v...
Check all caps around horiz drive xformer = an ESR meter
helps on this one + a skilled, experienced technician......T.
Top Proton Televison & Video Experts
matt martin
matt martin
Bob Kirkwood
Larry
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
