STEP 1 : First check for the free space in the handset
- selece the option icon in the main menu
- scroll down and then select memory
- check for the free space in the device.If the memory is full then delete some application.
After doing all the above steps with out switching off the handset remove the batery and sim after few seconds reinsert them again.
For refreshing the handset .
STEP 2:
Check the old messages are deleting are new one if old messages are deleting then follow the below steps.
- Select the message icon from the main menu
- Press menu button and select the Option
- Select the general option
- scroll down and select KEEP MESSAGES as per your wish (30days, 15 days, forverer)
- After selecting any one of the option press menu button and select save .
if you select 15 or 30days the old messages will delete after 15 or 30 days.
If you select forever till you delete the messages it wont delete untill you delete them.
Step 3:
if the messages and call logs are deleting in between then there is problem in the handset software.You have to take the backup and then reinstall the software of the handset.
