Your camera can be defected. If you buy new batteries, and it still doesn't work, than you'll probably want to send it back to the manufacturer. First, call them and tell them your problem, and if that doesn't work, than you might want to carefully examine your camera, to check if everything is in the correct place, and their all working correctly.
Try taking a #2 pencil and use the eraser on the contacts inside the camera to clean them off. Dont use anything to rough. If this doesn't work try taking it to a local camera shop to get them to send it off for repair.
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
It's possible it's the flash tube and that its burnt out. Since an external flash works it doesn't sound like it's the circuitry which is a good thing. The flash tube being burnt out is fixable however it's a fix that needs to be done by a professional. If your camera is still under warranty you can send it into Nikon for repair. If it's not under warranty you can still send it into warranty or you can find someone in your area who specializes in camera repair (as that would likely be faster then sending it to Nikon). If you have anymore problems feel free to message me and I can help you out =)
If the LCD doesn't work at all, you can't see menus or play back old pictures then the LCD is damaged and needs to be replaced. Sounds like this is the case, it's about a $130 repair including the part, installation and return shipping of the camera. Hope this helps!
Thomas Drayton
Owner, www darntoothysam com Digital Camera Repair
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
try resetting your camera.
In record mode press menu.
go to setup tab
go up to reset
press right arrow
highlight reset
press set.
If that doesn't work Call the repairs center at 800-706-2534 and then keep choosing option 1. Tell them what's going on and that you would like to send it in for repairs. If they ask just lie and tell them you already talked to tech support. LOL
