? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Check fuel line for obstruction first then you need to disassemble your carb a give a full cleaning maybe even rebuild it. Check out this link and watch the chainsaw video. smalleng.com
The first thing is to clean the bar, oil ports, then the main port in the case, blockage is the main cause. When the bar area is clean, Take a stright pin and try and clean out the port as much as you can,then if you have a shop vac that has a attachment that goes to a smaller end, such on the port and get any lose dust out.
If this does not work the pump could need to be rebuilt.
Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
use a 32:1 mixture which is approx 4oz 2cycle oil to 1 gal of gas. you can also add an ounce or two of of a fuel sys cleaner to your fuel mixture for a good cleaning of the carb to remove any gum or varnish build up which could cause poor engine performance. hope this helps you
