Question about Dacor PCS130 Preference Electric Single Oven
PCS 130 Keypad
I am very dissapointed to report that my Dacor PCS130 wall oven has failed me. I have an all Dacor kitchen - 2 wall ovens, a microwave (whose display is also a problem as part of the numbers don't show up anymore.) and a gas cooktop. I even recommended a Dacor oven to a friend and she bought one!! Bad move on my part as they have had trouble also :(
My display is beeping and code F1. I tried resetting the breaker - no luck. Now I understand I need to replace the touchpad assembly for a mere $750 (service call included.) This unit isn't even 6 years old and doesn't get much use as I have two ovens!
Do I have to replace the whole assembly? Will Dacor cover any of the expense?
  • 28 Answers
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
Posted on Sep 28, 2009
SOURCE:
What does a C76 or C77 error code mean on a Dacor wall oven?
Page 9-48 in technical manual excerpts at the link below:
http://www.uncleharrywizard.com/nephewclub/WizardRange/dacor/dacor-wall-oven.pdf
It says to call for service (by a technician). (I am only reading it from the document - I am not a technician.)
It says to replace glass/touchpad assembly.
It says wrong or unrecognized diode configuration.
Apr 03, 2018 | Dacor Ovens
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
My oven flashes and beeps F 4. What does it mean?
F4 on a Dacor oven is a bad temperature sensor.
The temperature sensor is inside the oven up high on the back wall
Mar 29, 2011 | Dacor PCS130 Preference Electric Single...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Oven displays F4
The temperature sensor is inside the oven up high on the back wall.
Jan 16, 2010 | Dacor Ovens
Dacor preference oven
Did you turn off the circuit breaker for 30 mins?
Oct 01, 2008 | Dacor PCS130 Preference Electric Single...
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
Aug 31, 2007 | Dacor Millennia MOV130 Electric Single...
Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Feb 05, 2007 | Dacor Millennia MOV130 Electric Single...
Open Questions:
Ovens Logo
470 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
