I have two Pure-lon Air Filters and both machines the red 'clean filter' light will not stop flashing even when I have just cleaned the filters. There must be a way of cancelling the warning light.
Thanks.
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
A lot of these things have a reset method where you hold power (or whatever button's around to do the job) for 7-10 seconds on starting it up again....
Called Brookstone and was told turn unit off lay on side remove cylinder put unit upright reinstall cyclinder and hold pwr on for 5 seconds.
My pure ion (non-advanced) was doing the same thing. I did a few different things while trying to fix it and am not sure which one worked but it is fixed. 1) I unplugged the unit and took both filters out. 2) then wiped off the 5 metal contact areas in each of the filter slots on the unit with my finger, I also wiped off the metal contact area on the filters themselves especially where they contact inside the unit. 3) I plugged in the unit (without inserting the filters) and pressed the power button (it blinked once) 4) Then I inserted the filters and powered it on. And voila! no red clean filter light!! Hope this helps yall! I just wish I knew exaclty which thing fixed it.
Turn unit off.
Hold the power button & fan speed button for 10 sec. release both than turn it back on...
Wella:):):)
same here
Same problem with "change filter" red light continuing after filter is changed.
we have the same problem and holding the start button down for 10 sec did not help
Clean filter light would not go out.Tried to turn power off and hold power putton in for approx 10-15 seconds. No luck - than tried and held fan speed and power button simultaniously and it worked -- thanks for all your help
Yes.Hold the power button for about 10-12 seconds and the red light will stop flashing
