Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
Posted on Sep 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont turn on light just flash back and forth on speed setting
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Sep 26, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288672
Points
1801
Gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,001 Answers
  • Posted on Dec 09, 2016
wwlvictoria
Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603686
Points
6027
Quick Charger 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
3helpful
2answers
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
My wf310 1100 spin will not do a high speed spin
hi, there may be not enough water draining out on the last cycle before it spins so i'd give the pump a good luck over also check the filter if it has 1, and check the drain hose. the other fault could be the module control board this controls the motor speed hope it helps
regards
shaun
1helpful
Just bought the G-Speed Q 8TB. Hooked it up and the red warning light on the bottom is flashing. Is there something wrong with the drives?
The flashing red light is indicating that it is building the RAID5 parity information. If there is an alternating amber/blue lights on one of the drives blinking back and forth with the red light it is indicating that it is building/rebuilding the RAID5.
1helpful
Turn signals wont flash but somtimes,bulbs good whats wrong? they light up front and rear but will not flash.if i mess with switch back and forth fast they will start working and by the end of my ride...
If they both come on, front and rear, but won't flash, then the most likely problem is the winker relay. When you flick the turn signal switch and they sometimes flash, that's because you're working the relay repeatedly and jarring it into action. Try a new realy (the box that makes them flash) and you should be fine.
Black flashing on screen where light is
This allows you to see where your photo is over or under exposed. It helps you see if the exposure is set right.
You can turn it on and off by moving the Up/Down/Left/Right button up or down. This will move you thorough the image data (shutter speed, aperature, file format...etc.). It should show "Highlights" on the screen when you have this selected.
The alarm wont ssut off
lol, i had the same problem, come to find out it was just the battery was dead, and when ever you let a car sit the battery usually may just need to be re-charged.
1helpful
2answers
Vent fan
Check manual. Fan has been on 30 hours. Reset counter by holding "-" for ~5 seconds.
99 windstar
sensors rarely go out i'd try first check brake fluid top it off this can cause brake light to come on if full check yor brake pads and rotors you got to take your tires off any rust will set off the brake light inside your truck if they are fine then you should get your ball joints and tie rod ends checked out by a pro
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
