I have accidentally formatted my Tomtom One(4N00.012) SD card without backing up all data.I copied all maps and other stuff from another Tomtom One to my computer's hard disk and then transferred all data to My Tomtom one.But when i turn on my tom tom it displays No Maps Found.I despratly need help to solve this issue.Plz Help me!
I have accidentally formatted my Tomtom One(4N00.012) SD card without backing up all data.I copied all maps and other stuff from another Tomtom One to my computer's hard disk and then transferred all data to My Tomtom one.But when i turn on my tom tom it displays No Maps Found.I despratly need help to solve this issue.Plz Help me!I have accidentally formatted my Tomtom One(4N00.012) SD card without backing up all data.I copied all maps and other stuff from another Tomtom One to my computer's hard disk and then transferred all data to My Tomtom one.But when i turn on my tom tom it displays No Maps Found.I despratly need help to solve this issue.Plz Help me!
AnonymousApr 02, 2009
no maps foundno maps found
You can't post conmments that contain an email address.
The problem with that approach is that you cannot transfer maps from another device onto yours without product key activation codes. This is to prevent piracy or abuse of maps on individual devices.
You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
Hi, First you need to have the relivent map on your SD card. Typicly this will be the Tomtom Map " Western Europe ". When you purchase maps from TomTom you also get an activation code and instructions telling you how to install the map onto your device and how to authorise it using the code that comes with it. Before doing anything ... BACK-UP your existing data ( the whole SD card ) onto your computer . This will ensure that if any update is unsuccesful you can at least return things to the way they were before you tried to update. There are several ways to obtain maps
buy a new TOMTOM SD card for your tomtom that containes the required maps. Make sure it comes with the authorisation card.
buy a CD from TomTom or a TomTom authorised dealer . This CD will contain the required map so you can download the required map to your own SD card. Make sure it comes with the authorisation code AND instructions.
buy the required map from TomTom online . You can download it to your PC , then copy it onto your SD card later. It will come with some instructions and authorisation code ...... You can also use "TomTom Home" software and this does most of the job of downloading maps ( that you buy from tomtom ) and puts them onto your sd card for you in a semi-automatic way . If you go down this route then its best to be sure you have the latest version of TomTom home software by going to the TomTom website first.
With ANY of the above methods------- BACK UP your existing SD card first . In fact ... make a BACK UP NOW , then if anything goes wrong at any time , you can at least revert back to your backup.
You cannot take maps from one TomTom and put them on another TomTom. The maps are coded to that particular TomTom. It would seem the only option left to you is to purchase another map from TomTom.
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
I am very sorry to hear that you had no backup. Theres no way you can recover data once you have deleted it from an sd card. BUT , If you still have the authorisation card ( thats the one that generates the activation code ) then you might be able to copy data from another tomtom card to your card then reactivate it with the authorisation card. GOOD LUCK.
OTHER TOMTOM USERS NOTE: Backup your SD Card.
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Yes you can buy a new card with all the map data on it. You can also search the internet for a program to "unformat SD card" only if you didn't write any new information onto the formatted SD card
Try removing your SD card and inserting again. If the problem persists then I recommend you use your backed up copy to restore the SD card. You did make a back up on your PC, right?
The other possibility is that in the preferences section of you tom tom the wrong map has been selected or a map that it cannot read has been loaded. Remember newly purchased maps must be activated first before use.
I made a copy of may original SD card and use that in my tomtom. If anything goes wrong, I can always restore it from the original. I also made a copy on my PC using the Tomtom "Home" application.
no maps found
