Yamaha RX-V2700 Receiver Logo
Posted on May 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
I have a Yamaha receiver, RX-V2700. i connected a hdmi cable from my televison to the receiver. I then connected another HDMI cable from my cable box to the receiver. i get no audio or video from the receiver.
I connected the receiver to the cable box with an optical to get audio.
How can I get audio & video through the HDMI cable through the receiver
  • 2 more comments
  • Lboogie2305 May 22, 2008
    well I would like to make full use of the HD capability of the receiver. do you not get the highest quality of HD programming through the HDMi cable?
  • Anonymous Mar 13, 2014
    my rxv367 would'nt turn on, if I remove hdmi cable from satelite box it will power up, plug in hdmi cable and off goes receiver.
  • Anonymous Mar 15, 2014
    Tested HDMI Cable Tested TV direct from Cable box. FM Receiver outputs Audio
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Yamaha Master 1,001 Answers
  • Posted on Jan 17, 2017
wwlvictoria
Yamaha Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603922
Points
6027
Portable Bluetooth 4.1 Receiver Wireless Multipoint Connection Audio Music Adapter with 3.5mm AUX Port and Hands Free Calling for Home Audio Music Streaming Sound System https://www.amazon.com/Charm-Bluetooth-Multipoint-Connection-Streaming/dp/B01G8219Y4/ref=sr_1_4?ie=UTF8&qid=1484619390&sr=8-4&keywords=Charm+sonic
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
  • Posted on May 22, 2008
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563513
Points
4850
Why not you use a normal AV cable
instead of hdmi cable
  • Anonymous May 22, 2008
    yes you do.
    but i want to make sure it works with AV cable
Yamaha rx-v367 and internet tv audio
try connecting the hdmi out from cable box to your tv hdmi input, and leave the hdmi out from tv to the reciever where it is, leaving reciever selected to 'TV' and yes, a sub matters (it is not part of your problem but you need the bass a sub provides)
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
2answers
I need to hook up a yamaha 465 receiver
It has two HDMI inputs and one HDMI monitor output for the TV, so assuming all your devices are HDMI-capable, YES.
http://www.crutchfield.com/p_022RXV463/Yamaha-RX-V463.html?tp=179&tab=features_and_specs
1helpful
What kind of up-grades are for the yamaha
There are no "upgrades" however, if your having problems with HDMI switching or "not working" You can send it to Yamaha and they will replace the HDMI board at n/c. It's still version 1.2 and the current version is 1.3a soon to be 1.4. What is it that you need to have upgraded? Post a comment with what it is you would like your receiver to do and I can help you further. I work with Yamaha daily
No sound from cable via V665 receiver
Can't pass HDMI thru this or any other receiver with version 1.1,1.2,1.2a,or 1.2b. HDMI is riddled with issues! it's not Yamaha, it's HDMI. The current version 1.3b is working "so far" If your receiver is still under warranty, Yamaha will update the software and hardware at N/C. If it's out of warranty, Run HDMI directly from source to TV and Audio to your receiver via optical or digital coaxial. For more info than you can process, google "HDMI forums" and there are over 73,000 posts/sites/etc. If you need further info, post a comment and I will be glad to help.
1helpful
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
3answers
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
