After switching on with the remote I lost the picture, sound was ok. I checked the power supply for leaking condensators none of those. As none of the backlights was working I looked for a failed component in the common part for all inverter circuits.I found a blown SMD fuse F1 1.0A/67V on the inverter board near the connectors to the power supply. Soldered PCB type fuse on top of the SMD one. TV-worked.again.
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
