Question about HP LaserJet 2200 Printer
Problem printing multiple pages on one sheet!
I have created a document in Word that is in Landscape layout. I have made 4 copies of it on the Word page, and I want to print it out as 4 pages on a single A4 sheet of paper.
On the print menu I select 4 pages per sheet, and on properties I make sure that it is in Landscape, but when it prints it is as if the printer has printed the pages as portrait, as each word page is one eigth of the A4 printed sheet.
If I select 2 pages per sheet, they are printed correctly, each page being a landscape quarter of the printed A4 sheet.
Where am I going wrong?!!
  • Kevan May 22, 2008
    I should have mentioned that I had already tried that route. The problem with that is that you get a faint border printed around each of the 4 pages on the one sheet - not what we want.
    I've found with other (non-landscape!!) work that using the pages per sheet in the 'zoom' box on the first print box does not create these lines.
    It's just that with this landscape work it's creating this problem!
  • 922 Answers
The problem is the PCL5 driver.
Replace it with a PCL6 driver.
Apparently, Microsoft issued an update that broke PCL5 drivers.
Perhaps they were trying to save paper. LOL!
Posted on Jun 06, 2009
  • 39 Answers
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
Posted on May 22, 2008
SOURCE:
UNABLE TO PRINT LANDSCAPE AFTER 1: OPEN SPREADSHEET FILE 2: GO TO PRINT 3: GO TO PROPERTIES 4: GO TO PAGE SET UP & CLICK LANDSCAPE 5: GO TO PRINT PREVIEW(DOES NOT SHOW OR PRINT LANDSCAPE)
You need to change the page layout within excel set it to lancscape.
for excel 2007
Look along the top ribbon and click on "Page Layout"
then select "orientation"
and change to "Landscape"
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
To print photos in landscape orientation use Irfanview. Install this software and use it to view photos. Very easy settings are available in print options from its options menu.
To print documents in landscape, choose landscape orientation from page layout.
For all other applications, set the orientation from the printer's properties inside the control panel in Windows.
Note: You cannot adjust it to print in landscape for direct copying from the printer's panel.
Dec 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Flipping a page in Office 2003
I think the problem is not affecting by changing the layout from portrait to landscape but specific to the text box layout.
You will have to format your text box to either wrap text, or 90 degree angle - once you have done this on one box you will be able to copy the format to other boxes using format painter.
Apr 21, 2009 | Microsoft Word 2003 for PC
Trouble printing book made in Word 2007 using a HP psc 1315 print
Select the Page Layout tab, in the page setup group, select margins, The at the bottom, select custom margins. on the margins tab about 1/2 way down, select the down arrow next to Multipl epages and select 2 pages per sheet. Print a couple test pages and see if that is the setup you need.
Apr 06, 2009 | Microsoft Word 2007 for PC
I am working with a Ricoh Aficio 3260 machine. I have been sent a 20-page Publisher document laid out in Landscape, each page is set up as 8.5 x 5.5. I want the Ricoh to produce a booklet stapled...
Well, I don't have a document in that format exactly to play with, but assuming you are using the PCL 5c driver, it should be a fairly simple task. If your using another driver (ie: RPCS) then it will be similar, just a little different looking dialog box.
Open your document, Select "Print", select "properties", you can change the "orientation", and "layout" (pages per sheet), 'duplex', and staple (assuming you have a booklet finisher installed and configured in your printer properties). There is an icon in the left corner that changes with the settings and should help you with the them. Obviously, you should only print 1 set, or even just a page or 2 to check the output. These types of things are always a bit of trial and error until you have done it a couple times. I hope this helps
Mar 06, 2009 | Ricoh Office Equipment & Supplies
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Apr 11, 2008 | Xerox Office Equipment & Supplies
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Feb 10, 2008 | Adobe Photoshop 7.0 for PC
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
Open Questions:
HP LaserJet 2200 Printer Logo
2,215 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
