Hi i was reading regarding WAP settings for BPL mobile...I have copied and pasted what i saw from different forums...see if it is of any help
you can manually conigure GPRS in your mobile phones.
BPL_WAP
homepage
http://wap.mizone.bplmobile.omSession mode permanent
connection security off
data bearer gprs
gprs access point mizone
IP address 10.0.0.10
authentication type normal
login type automatic
BPL_MMS
homepage
data bearer gprs
For those who are interested in using GPRS facility provided by BPL Mobile (Mumbai only) here are the brief n settings required for it. You can also use this for surfing Internet through you PC provided your PC is connected to your mobile using Data Cable or preferably BlueTooth.
Go to the main menu and open “Settings”
Select “Configuration” and then “Personal Configuration Settings”. Create a new configuration settings by selecting “Add New” from “Options”
The account fields should be filled as below:
Account Settings
Account Name : bplweb
HomePage : http://wap.mizone.bplmobile.com
User Name : Your mobile number
Password : bplmmsc
Use Preferred access point : No
Access point settings : As given below
Proxy : Enabled
Proxy Address : 10.0.0.10
Proxy port : 9401
Data bearer : Packet data
Bearer settings : As given below
Bearer settings
Packet data access point : mizone
network type : IPv4
Authentication type : Normal
Password : bplmmsc
Now once you have done that get back to “Personal Configuration Settings” select the new account “Bplweb” that you have just created and go to “Options” and click on “Activate”
Go back to the main menu and open “Settings”
Select “Connectivity” and then “Packet Data”
Set the “Packet data connection” to “When needed” and then click on “Packet Data Settings” then “Edit active access point” and then set “Packet Data Access Point” to bplgprs.com
These instructions are according to the Nokia sets 3110c, 6085 and should not differ much for other sets and brands and in case of which you can always go to the customer care as did.
BPL WAP SETTINGS FOR MOBILE PHONES
Connection name:-
BPL WAP
data bearer:
packet data
Access point name:
mizone
User name:
919821099800
Prompt password:
no
Password:
bplmssc
Authentication:
normal
Homepage:
http://wap.mizone.bplmobile.com/
ADVANCED SETTINGS
network type:
IPv4
Phone IP address:
automatic
DNS address:
automatic
Proxy server address :
10.0.0.10
Proxy port address :
9401
Hope this helps !!!
